Help!
Find out what it takes to sign up, how to contact the board admins, and more.
Moderators: oregonsage, OMRA, dlharte, Tawmass
OMRA
Help!
Postby OMRA » Fri Dec 15, 2006 2:41 pm
If you're having problems problems with our message board, post away and we'll do our best to figure it out. :D
rzr101
Postby rzr101 » Sun Apr 24, 2011 2:56 am
Test
John Evans KTM 450 XCF 2FU XC and GP
Postby Tawmass » Sun Apr 24, 2011 5:43 am
FYI, your picture did not show because you ended the filename with .HTM. It should've ended with a picture filename like .JPG - like this:
Code: Select all
[img]http://m1123.photobucket.com/albumview/albums/rzr101/photo.jpg[/img]
rzr101
Postby rzr101 » Sun Apr 24, 2011 9:19 am
Thx Tawmass ... One more time
JoeMcLaughlin
Postby JoeMcLaughlin » Sun Apr 24, 2011 9:42 am
rzr101 wrote:Thx Tawmass ... One more time
You want to use the address of the picture. You are real close. If your using Internet Exlporer right click on the image then view the properties,, copy the image address (URL). If your using Chrome right click on the image then select the copy image URL option. For Mozilla Firefox right click on the image then select copy image location. Photobucket is tagging on a little junk at the end of the address that you will need to delete, everything after .jpg
Joe........
JoeMcLaughlin
Postby JoeMcLaughlin » Sun Apr 24, 2011 9:43 am
Code: Select all
[img]http://mob1123.photobucket.com/albums/l549/rzr101/photo.jpg[/img]
rzr101
Postby rzr101 » Sun Apr 24, 2011 7:38 pm
test from pc
Image[/img]
rzr101
Postby rzr101 » Sun Apr 24, 2011 7:39 pm
rzr101
Postby rzr101 » Sun Apr 24, 2011 7:48 pm
I think PC works fine but mobil safari will take some thinking ...
rzr101
Postby rzr101 » Mon Apr 25, 2011 11:57 am
Ok I think I figured out mobil
Dlow2686
In First Gear
In First Gear
Re: Help!
Postby Dlow2686 » Wed Apr 02, 2014 5:08 pm
Can't get an avatar to upload? ...
Dlow2686
In First Gear
In First Gear
Re: Help!
Postby Dlow2686 » Sun Apr 20, 2014 11:53 am
still cant get an avatar to upload... someone please help...
mudpie
Re: Help!
Postby mudpie » Sun Apr 20, 2014 4:01 pm
Probably trying to use a file that is larger than the parameters allowed. Try re-sizing or using a smaller image.
I forget what the dimensions are.... Tawm?
You may all go to hell, and I'll go to Texas.
If you can't stand behind our troops, feel free to stand in front of 'em.
Re: Help!
Postby Tawmass » Mon Apr 21, 2014 7:13 am
Avatar dimensions must be within these specs:
Size: 20k bytes or less
Minimum: 20x20 pixels
Maximum: 250x250 pixels
Return to “Forum Guidelines and Help - Newbies, GO HERE FIRST!”
